I have an application where I need to control the speed of a VFD from an encoder mounted to a conveyor shaft. Unfortunately, the VFD I must use will only take a 0 to 10 vdc analog velocity command. Does anyone know of a source for a stand alone frequency to voltage converter?
input frequency will range from 750 - 1000 pulses/sec to 100,000 pps
a quad b encoder with line drivers
many thanks!
many thanks!
