P
Need to build a Fuzzy logic control using Matlab Toolbox for controlling the pH of a liquid. There are 2 valves to be controlled. One contains base and the other acid.
Need to build a simulation toolkit using MATLAB and simulink. Want to build a control diagram to reflect the changes. The set point is x. If i pass x1 value, the fuzzy logic should open the valve accordingly and try to bring the pH of the liquid to the set point x by varying the 2 valves.
Help required.
Help required.
