Can we increase gas flow throughput through compressor plant by adding more gas reserve?
we have seven centrifugal compressors installed in parallel as well head gas compressor to boost the pressure of natural gas coming from producing well. Each compressor have two casings namely LP and HP. Our Natural gas field has depleted and reach at suction pressure to 15 Bar(g). Now we have drilled some more wells. After adding of more well can we increased the flow delivery through compressor plant keeping in mind that the pressure of new wells is more or less the same as of previous wells i.e. 15 Bar(g).
Appreciate your guide lines
