hi
i want to ask a question about Gas turbine Frame 9e DLN 2.1. we are operating machine on Gas fuel it has three manifold. like to say 3 GCV and 1 SRV
1. primary manifold
2.secondary manifold
3.transfer manifold
can any one tell me what is specific load for using these three manifold when these three valves comes in operation
Other question is when we are using gas fuel what are the use of controlling mode like. Why we can not keep unit on Lean Lean Extended mode what are disadvantages. Why we need to keep unit on Premix mode what is benefit for gas turbine.
1. Lean Lean Extended
2. Lean Lean Base.
3. Premix mode
4. Lean Lean Negative
5. Lean lean Positive
Kindly give a detailed description of above issues
1. primary manifold
3.transfer manifold
2. Lean Lean Base.
3. Premix mode
