K
Hello! CSA
I have one question here.. If Turbine speed is kept constant(5100rpm=50Hz india), Ambient temperature is constant(say25degC),
Inlet guide vane is constant(84DGA). ( I am running the GT on Isochronous mode independently-i.e. not connected to grid.) If plant load varies by 3-4 MW will there be any change in Air flow?
Actually i want to know that is there any change in Compressor Air flow at 30MW Preselect load(ambient 25degC & above condition ) and 30MW base load(ambient 28degC and above condition) ?If there is change in Air Flow then How?
