Hello Folks
We have 02 Gas turbine(GE Frame 5) of 18 MW Capacity, and controlling system is MARK-VIe. Recently, we have faced "High Exhaust Spread Problem" twice and we had shutdown the Unit. We cleaned/replace the fuel nozzles twice, and recently we have installed knock out vessel for condensate capturing from Natural Gas. After second time nozzle replacement, Gas turbine performace was much better and spread was around 19 20 Degree C. But now as time is passing on, Exhuast Spread is again increasing and reach to 29 C. The point to be noted that, power load ramained constant and Difference between thermocouple showing lowest temp and TTLT(Low temp trip limit) is almost constant=19-18C.
Need your kind suggestions and comments/recommendations.
Thank you
Thank you
