Gas Turbine High Temperature
  • Thread starter Engineer Sonny Amaiko
  • Start date
E
This gas turbine is European Gas Turbine Type TB 5000. It had Alternator High monitoring device. The capacity of the turbine is 2.8 MW. When this turbine is in operation, it can only carry a load of 1 MW. Then the operating temperature high indication will show on the temperature monitoring device, thereby making the GAS GENERATOR to exceed 100 percent of normal tuning conditions.
