R
Frame 5 gas turbine tripped on hydraulic oil low pressure. On cranking Hyd. oil pressure was 0. Hydraulic supply pump, check valve and relief valve were replaced. This solved the problem. However no observation found in pump.
We have two GE frame 5 gas turbines MS5001P. Recently one machine was shutdown on hydralic oil low pressure. Hydraulic Supply pump is Delavan axial piston pump with standard pressure compensator (VPR3).On cranking hydraulic oil pressure was zero. we replaced the hydaulic supply pump, check valve and relief valve(mounted on hydralic supply manifold). on start up pressure was restored to 60 Kg/cm2 which was increased to 80Kg/cm2 by releief valve adjustment.
Latter no observation found in pump i.e. shaft, rotor, plungers and plunger springs were OK.
Please immediately advise what can be reason of hydraulic oil pressure dropping to 0 suddenly.
best regards
best regards
