There is two gas turbine running in parallel (island mode) to supply process plant which is not connected to external grid.
In case, one running machine trips, PLC based block load shedding scheme acts, which sense the trip and accordingly cuts the downstream load (calculated amount) instantly.
The calculation is simple,
say GT-1 and GT-2 is running with 10MW and 5MW load, if GT-2 trips, plc calculates (5MW-3.5MW), i.e1.5 MW load to be shedded.
3.5MW is the step load capacity of GT-1.
My question is, how this 3.5MW is calculated. There is no documentary calculation available with us how 3.5MW is calculated.
The machines are frame-V and Frame-3 GE make gas turbine with mark-VIe speedotronic control.
I am trying to calculate the ramp rate 3.5MW/Sec.
Please help me to calculate the ramp load capacity from gas turbine manual/mark-VIe manual.
Manuals as well as system is available to check.
