K
Hi all,
We have 2 GE Frame 9E Gas turbines at our facility. The gas turbines are designed for a base load of 115 MW at an ambient temperature of 28 degree Celsius. The gas turbine has 3 bearings located before the inlet plenum, inside the combustion chamber, and after the exhaust frame. There are 2 more bearings on the generator & one on the exciter [which is overhung].
Recently, one of the gas turbines is showing a high shaft vibration on the exciter overhang bearing. The displacement value is in excess of 150 microns i.e. it is out of scale of the [Bently Nevada make] vibration pick-up. During the previous shutdown, since we had doubts as to whether the pickup might have been malfunctioning, we had it replaced. However, still it is showing the same value. If this value is correct, is it likely to cause any secondary damage? The vibration people are convinced that it is of no concern, since the seismic vibration velocity values are well within limits. Besides, the gas turbine trip logics are also based on seismic vibration velocity values i.e. 25.4 mm/s for at least 2 out of 3 gas turbine or generator-exciter values.
Any help from experienced vibration/operation personnel is most welcome.
