Gateway for custom function codes.
Joshua Smith
Hello.
I am working with an Modbus slave electrical meter in which the manufacturer implemented a non-standard modbus function code (Electro Industries Nexus 1262, Modbus function code 23h). The only available meter communication port is 2 wire RS-485, serial Modbus RTU. I need to convert this to Ethernet Modbus TCP, and communicate to it with the custom function code. I have tried a Ruggedcom and a Moxa RTU to TCP converter, but they just reject the any packets with the custom function code request. Does anyone have an converter product that will pass a non-standard function code?
Thanks for your help.
L
Lynn August Linse
That's odd, as custom functions are trivial to handle as long as they respect the max length limitations and CRC form of Modbus/RTU.
The Digi and Lantronix products don't mind custom functions codes, but your timing could change because they use smart size-estimation for known functions, but always use the character timeout for unknown functions.
Are you sure the problem with rugged & moxa is not just timing related? try adjust the character/end-of-message-detect time out.
