I'am trying to make a simulation of the ge 324LU ALTERNATOR but i can't find all the data characteristic of the machine any help please!!!
Hello All,I'am trying to make a simulation of the ge 324LU ALTERNATOR but i can't find all the data characteristic of the machine any help please!!!
gaz turbine ,i am trying to get all the design parameters of this alternator for my master thesis.Hello All,
Alifedjoun,
Could you tell us the type of machine coupled to kind generator, is it Gas/steam or other type of... turbine/prime mover? ...
One should get these informations from OEM manuals , capabilities curves , types datas informations characteristics should be described in those manuals .
At least if you can aswer to the above question we could get some search for that.
Hope this help ,
James
I just have found that it is 9FA generator so let me see if any of my colleague can forward such informations , i am not sure about getting ok for that .gaz turbine ,i am trying to get all the design parameters of this alternator for my master thesis.
such us number of slot stator and rotor dimensions.....
thanks
hello jamesI just have found that it is 9FA generator so let me see if any of my colleague can forward such informations , i am not sure about getting ok for that .
As i wrote before only Owners of powerplant can have kind of documents as it is forwarded by OEMs
So i guess that it would be very difficult to get it.
James
Hello Alifedjoun,hello james
i will be so grateful if you can help me because i couldn't start my simulation in ansys if i don't get all data of this generator and i have to present my thesis soon
regards
Ali
hi jamesHello Alifedjoun,
This some datas i just get from a guy who did a thesis on the Ge 324LU generator:
Alternateur :
Type : 324LU
Constructeur : GENERAL ELECTRIC COMPANY
Puissance apparente :308000 KVA
Puissance active : 261800 KW
Facteur de puissance : 0,85
Fréquence : 50Hz
Nombre de pair de pole : 2P=2
Vitesse nominale : 3000 tr/min
Couplage : Etoile (Y)
Classe d’isolation : F
Poids : 278374 kg
− Excitatrice :
Type : Statique
Puissance active : 1146 KW
Courant continu : 1857 A
Tension : 617 V
Pression gaz hydrogène :413,7 kPa
It is written in French but it can help for instance,
Also what are you trying to simulate on this model??
Since they are some thesis on the web about starting generator by LCI (LSI from Ge)simulation
I advise you to have a look on this thesis.
Are you needing datas like slots number or other damper and inudctance reactance ration values?? For your simulation or just for information on your thesis?Since it not easy to get kind datas §§§
Hope this can be an help,
James
Hi Ali,hi james
what i need the most is:
stator and rotor inner and outer diamètre
slot number in rotor and stator
slot dimensions
stator and rotor length
regards
ali
hi jamesHi Ali,
I am sorry but this is what i can do by now , as the informations that you need is for sure only avalaible for OEM and power plant owners.
I know some guys like winders for GE /ALSTOM but for sure they can not diffuse kind of information here or on the web.
James
You are welcome dear Alihi james
any way thank you very much
regards
ali
by Gunner Scott
by Bob Odhiambo
