K
Dear Sir,
We are operation two GE 7FA DLN 2.6 units
When checking the daily log I found almost 10 DEGC difference in CTD (compressor discharge temperature) between two units
Here are the data of GT#01 & GT#02
GT#1
MW# 159, CTD#405.42 degc, CPD# 14.528 Psig, Exhaust mass flow# 425.33 Kg/sec
GT#02
MW# 162.94 MW, CTD# 396.67 degc, CPD# 14.587 Psig, Exhaust mass flow# 427.75 Kg/sec
I wonder as per the gas laws, if your CPD is on higher side your CTD also proportionally Increase. but you can see the above data, GT#01 CPD is less than GT#02 but still GT#01 CTD is 10 degc higher than GT#02.
I have put the trend as per the trend I observed that when exhaust mass flow on higher side CTD reduces & when exhaust mass flow lower side, CTD tends to increase
Could you please advice
KKK
GT#1
GT#02
KKK
