Dear All,
We recently overhauled one of our 25MW GE Frame 5 MS5001PA Gas turbines with Sentinel C control system. It's been a little over six months since the unit has been running. For the past one month, we have been experiencing a high bearing drain temperature on Bearing No2 with LTB2D reading getting as high as 108-110 degrees Celcius at <16MW.
The following are the oil parameters;
Lube oil header pressure: 1.75bar
Main Lube oil pump discharge pressure: 2.6bar
Main Lube oil header temperature: 63 degrees Celcius at an ambient of >30degrees with 3 lube oil cooler fans running
We have pressure washed the off base lube oil coolers, to improve the cooling but no positive effect. when compared to the other units of same capacity but with MK V control system, the temperature a relative okay, with the highest value of 98 degrees Celcius.
Please what could be the cause of the high bearing no2 drain temperature?
