Greetings All,
Cleaning the Air Inlet Filters of the GE Frame 5 Gas Turbine with Pressured Air and Running water is time-consuming, which is done independently until the 288 Filters are cleaned. We are presently in need of other means of cleaning the Filters in a better way and less time-consuming before total replacement.
Could you please suggest to me the easiest way for the Filter cleaning, either with a particular machine/device or any other means?
Thank you all in advance.
