F
Hi every one
We have a GE frame 5 Gas Turbine MS5001P coupled to Generator through reduction gear. Recently during shutdown high axial movement observed on generator rotor. Reduction gear is double helical. Pinion is coupled to turbine through gear type load coupling. Bull Gear shaft is hollow and a quill shaft is inserted in it. Generator Rotor is coupled to bull gear using quill shaft. Quill shaft has integral flange at generator end which is bolted to generator rotor flange. At the other end quill shaft has splines on outer dia and a hub with splines at inner dia is installed on quill shaft. This hub is bolted to gear. As per GE manual Hub is installed with positive interference on quill shaft. There is no thrust bearing for pinion, bull gear and generator
Load Gear was manufactured by GE Lynn. Type is S-634
As per my understanding generator rotor along with quill shaft should be able to slide inside hollow bull gear shaft in order to allow generator rotor to attain its magnetic center in operation.
Please advise if some one has experience of disassembly of load gear quill coupling on MS 5001P units.
