GE Mark VI Manuals
Sheheryar
Good day to you,
I was looking for control logic manual for MARK VIE control system. We are currently operating GE frame 9E machines. We have recently upgraded our control of mentioned machine from Mark IV controller to Mark VIe controller. I will appreciate any help on this query.
Best regards.
Sheheryar,
You will find electronic copies (.pdf files) if almost all the Mark VIe manuals on the hard drives of the HMIs supplied with the Mark VIe turbine control systems.
They are usually in at least two locations on the hard drives; search the hard drives for "GEH*.pdf" (without the quotation marks).
I always recommend once the location is found to put a shortcut on the Desktop to easily access them.
You will need to log in to MS-Windows with Maint or Administrator login privileges. However, I believe you can copy the folder(s) with the files to the Clipboard while in Maint or Administrator level, then paste them to the 'oper' level Desktop.
There should also have been a DVD (often several) provided with the Mark VIe upgrade which has all the manuals.
Hope this helps!!!
