GE Six Series to 90/30
Amr Elaguizy
1. Is there a software that could convert a Ladder diagram from GE series six to PLC 90/30? 2. Is there a software to communicate with GE PLC's such as 90/30 or 90/70 that is a window base. I do have GE software which is dos version? I know PLCDIRECT had an excellent window base but does not communicate with the newer GE Fanuc, although it did communicate with some of GE series one processors. Amr
Steve Bailey
> 1. Is there a software that could convert a Ladder diagram from GE series six to PLC 90/30? Nope. You'll have to translate it yourself or hire somone to do it for you. > 2. Is there a software to communicate with GE PLC's such as 90/30 or 90/70 that is a window base. I do have GE software which is dos version? I know PLCDIRECT had an excellent window base but does not communicate with the newer GE Fanuc, although it did communicate with some of GE series one processors. Yes. Its called VersaPro.
Yes there is a Window programming software from GEF. It is called VersaPro. It will program the Series 90-30 and 90-70. If you need more information please let me know.
F
Francus, West (IndSys, GEFanuc, Albany)
Have you called 1-800-gefanuc (433-2682)? I do not have experience in programming PLC's, but I thought this could help. 1. I found a series 1 to 90/30 translator on http://www.gefanuc.com/support/plc/f-s9030.htm "This file contains last minute information on the Series1 to Series 90-30 translator. The current version is 2.01a. This version is functionally equivalent to version 2.01, but creates teach-in file headers compatible with Logicmaster version 6.60." would this help? 2. for a programmer, see GE's VersaPro http://www.gefanuc.com/products/controllers/category.asp?cat_id=34 http://www.gefanuc.com/products/controllers/faq.asp and see CIMPLICITY at www.cimplicity.com for your HMI. Regards, West Francus GE Fanuc Automation
Thomas Swift
VersaPro will convert LM-90 programs for micro's,90-20's, 90-30's and (with the professional edition)90-70's. It will also convert Cimplicity Control programs for the same platforms. However it will not convert series Six ladder. GEFanuc will do the conversion for a fee, but in all likelyhood, it will be cheaper and more efficient to rewrite the code from scratch.
Dear Amr,
I really need in PLC software suitable for GE 90/30.
I would very appreciate if you could send me copy
of the program.
Thank you in advance.
Val
