P
I wrote a device driver in VB.NET. Now I need the data (integers) it gathers in Citect Tags. I could use SQL to do this (VB app -> Sql <- Citect). But is there no faster way, e.g. through VBA?
The driver/app doesn't run on the same machine as the Citect program, so I created a second program (VB.NET) which reads the values from the machine with the driver through TCP/IP. So I now have these integers available locally.
Should I write an Active X control? Or is there an easier way to do this?
