L
Lee Eng Lock
thanks for the observations, i am sure u will be happy with the results and the costs of using thermistors .
one specific area we looked into was the use of transmitters, and how to maintain end to end accuracy in the field.
a big advantage of thermistors is one can use rather high impedance units, eg 10kohms, 30kohms, etc and thus reduce the errors caused by length of wiring. for example, at 25degC the 30k thermistor has slope rate of 800ohms/1degC, while a 100ohm prt would be below 0.4ohms/degC.
one high accuracy scanner/voltmeter like the hp3457 would be cheaper than an array of high accuracy transmitters, which themselves would require power supplies, recalibration, drift with changes in field ambient temp, etc. if needed the scanner could also read one calibration channel with low tempco resistor to keep one's peace of mind. the error due to wire could also be nulled in some sense, since we can short the wires at the thermistor end and measure the ohms. i would not think it is possible to reliably maintain 0.03degC accuracy using transmitters, and for our application we are shooting for zero calibration for more than 5 years.
for a reference above 50degC i am not aware of "primary" standards like the gallium cell--there was some mention in the literature of some
hydrocarbon compound but looks like no one is making them commercially. i would use an oil bath, with the prt to verify the accuracy of the control setting.
rgds
leelock
rgds
leelock
