P
Dear Sir,
We are operating GE frame 7FA DLN 2.6 Gas turbines & HRSG (without diverter damper).
As per GT stop sequence, M/C will coast down gradually from base load (as per ramp down setpoint), breaker open, flame off & turning gear. It will take 24 hours to stop the "cooldown off" sequence.
To save the outage down time (of course money!!!!!!!) we used to do six hours of natural cooling just after M/C reach to turning gear & after we used to start the M/c on crank mode until wheel space temperature drops down to <65 degc.
During force cool, we also monitor the drum metal temperature difference (steam side drum top metal temperature- water side drum bottom metal temperature) if the drum metal temp difference increased to >40 degc, we used to stop the cranking & wait until drum metal temp difference drops to acceptable value.
I wonder we should not do any force cooling in gas turbine, force cool will affect the metal stress, damage the hardware at longer run.
As we don't have the diverter damper at GT exhaust, during force cooling we are giving stress to GT combustion hardware as well as WHRSG metal hardware also.
Is it advisable to force cool the Gas turbine & HRSG. Shall we have any impact at longer run? if we continue force cool the machine at this way?
Please advise.
[email protected]
Please advise.
[email protected]
