P
Dear CSA,
Recently, during shutdown (GE 7FA machine with hydrogen cooled generator GE make) we have measured the seal oil flow from float trap
Please find the below email communication:
Seal oil flow measurement on the hydrogen side of GT#1 was conducted. Data was taken with the following conditions.
1. GT#1 was at complete stop with axillary lube oil pump in service. (turning gear off)
2. Five (5) minute duration was used after stable flow was observed.
3. Total seal oil flow as read locally on the flow meter was 5 USgallon/min.
4. Flow was taken using the float trap by simultaneously manipulating V/V’s 123 and 106.
5. Seal oil differential pressure at 7.1 psi.
Total six (6) liters of oil was collected during the 5 minute measurement. Approximately 1.25 liters/min of seal oil flow was there with the above stated conditions were existing. It can also be concluded that seal oil flow at air side will be approximately 18 liters/min.
What would be the ideal flow rates at hydrogen side & air side? are the flow rates are different while M/C on turning gear & M/C on base load?
What would be the ideal time to measure the flow rates (on turning gear off, turning gear on or on base load)
regards,
Parag
regards,
Parag
