February- 2006
One of our Gas turbine (Mark V , 6581B) tripped on loss flame . Following alarms logged in the trip history.
Trip history showing
FSGR suddenly dropped from 18 % to 0.6%,
FPG2 dropped from 16.24 Bar to 10.3, then 6.6
FSG changed from 45 % to 43 % then 53%
Exhaust Temp TTXD 1,4,7,10,13,16 readings were in the trip history was showing minus value.
0433-12:19:05.406- True-Water cooling temp sensor fault
0110-12:19:05.468- True-Compressor Inlet T/C disagree
0419-12:19:05.468- True-Lube Oil tank T/C #1 fault
0257-12:19:05.468- True-Gas fuel temp high spread
0366-12:19:05.468- True- Air Atomizing temp measurement fault
0060-12:19:06.781- True- Loss of flame trip
We have replaced SRV servo valve and <R> core TCQA card.
Last September this unit tripped on loss of flame alarm and that was due to trip coil 20FG failure.
April-2006
Same unit tripped with exactly same alarm and trip history.
Checked 20FG coil, terminations, stroked SRV , everything working fine.
Replaced TCQA <R> core again. Now the Unit is running normal.
What could be the root cause of these trips ?
Is there any ribbon cable problem?
Any body knows the mark V card interconnecting ribbon cables GE part number ?
Earlier this unit was affected lots of signal traffic problems, so we disconnected local HMI from the <C> , so only one multiunit Remote HMI is connected to <C> core now.
After this modification following alarms not appeared so far.
DCC BMS: OUT OF MEMORY
DCC UNABLE TO GET DPM BUFFER FOR XMIT
DCC DPM: NO BMS MEMORY FOR ISR
DCC DPM: INVALID DESTINATION ADDRESS
How to make RC filters in the solenoid circuits?
Kindly analyze these problems
Kindly share your experiences and suggestions.
Thanks in advance
Joy
April-2006
Thanks in advance
Joy
