R
Gas turbine GE 9E 9171E Lube oil analysis. We are planning to start regular condition monitoring of GT lube oil.
The following are the problems faced:
1- which lube oil test should be carried out?
2-The frequency of lube oil testing?
3-which wear material test should be carried out and what does each test signify in terms of wear analysis?
