V
Hi.
Almost 300 Ltr water is observed in lube oil tank (Lube oil was filled almost 4000 Ltr out of 6750 tank capacity) of Frame-V machine due to lube cooler tube punctured. Machine is gas fuel fired and having Mark-Vie control system.
Machine scheduled cranking/ratcheting is already done before observed the water contaminates inside the lube oil.
SRV/GCV/IGV Servo shall be affected due to contaminated oil ingress inside the servo port.
Kindly guide us to help out which field instruments shall be affected in case of contaminated oil circulated inside machine internals and what type of maintenance to be carried out from instrumentation side after clean/replacement of lube oil.
