Heater Single Phase
N
NaveedHassan
what happens if i connect single phase heater load for load bank 220 volt to 440 volt?
R
> volt to 440 volt?
It will get too hot.
Can you re-arrange the elements?
If it's just a small load use a transformer to drop the Voltage.
Curt Wuollet
If I understand you correctly, I'd say you will create a light bulb, or possibly start a fire before it melts.
That would be 4 times the power.
cww
Bob Peterson
It is hard to say with any certainty, but if you are talking about hooking up a 220V heater to 440V you will get 4 times as much heat and this will likely result in a dramatic reduction in the heater's life.
