> a[n][n] and b[n][m] are two dimensional arrays. > These are passed to the procedure void gaussj(float **a, int n, float **b, int m)
What will be arguments in the calling program (main program)?
I have used following syntax: gaussj(a, n, b, m);
On compiling in VC++ (6) I get the following error: error C2664: 'gaussj' : cannot convert parameter > 1 from 'float [3][3]' to 'float ** ' > Types pointed to are unrelated; conversion requires > reinterpret_cast, C-style cast or function-style cast > Error executing cl.exe.
Sure, it isn't a Borland code?!? Many of the (sub)routines (Numerical recipes in C,...etc) don't work or are much too complicated for the thing they do.... There is a much simpler way of inverting a square matrix of unlimited size.... I'm not talking about Single Value Decomp. Techniques,...
One of the thing you can do, is to use cast redefinition, so your function need float ** but you, you have a data a[3][3] so don't call it by a but by (float**)a. ex : fn(float **var) { } don't call in main by fn(a) but by fn((float**)a) See you !
Please send some more details on this document. i want to know about parallel processing interface communication by process. i already referred M.F.C Class library in microsoft online help .
Regrads
Murali.
You should decalre a and b as pointer to pointer.For example.
float **a;
float **b;
the allocate memory using new or malloc;
load your a and b two dimensional array with the values. e.g. a[1][3]=5.6f; b[4][5]=5.53f;
then you can call the
gaussj(a,b,n);
// guassj code here....
gaussj(a, n, b, m);
