F
Dear Sirs,
We introduce a project based on the work with the equipment Schneider at the metallurgical plant. Fact of the matter is electric welding. Quantum with RIO was chosen as a control item. But we faced two very serious problems.
Needed:
1. Module that provides an impulse signal with the frequency outlet of 400 Hz. Changeable frequency from 0 to 400 Hz.
2. Module of the signal processing from the linear displacement sensor (maintaining SSI interface)
We’d looked through all the catalogues in sight but found nothing. Contractors suggest to turn from Schneider to Siemens 'cause they assure that Siemens has already a solution about the frequency outlet and SSI interface maintenance. But we need Schneider.
HELP! Top urgent! What other solutions can we have?
Ukraine
Needed:
Ukraine
