HELP! Read Input or Hold Input function code?
Stew
USING MODBUS RTU PROTOCOL MODE:
The Master Modbus wants HOURS, Minutes, and SECONDS from lets say . . . slave address 07hex.
Can I access HOURS, MINUTES, AND SECONDS with function 03 and function 04 interchangeably?
Will this work?
Read Input Register: 07 03 0067 0003 XXXX
Read Holding Register: 07 04 0067 0003 XXXX
note: 108 decimal = 67hex
Modbus Map database from Relay:
<pre>
Register# Description
100 Month
101 Day of Month
102 Year
103 Hours
104 Minutes
105 Seconds
(THIS IS ALL THE DATA I AM GIVEN!)</pre>
L
Lynn August Linse
This is strictly a vendor-by-vendor issue.
Some vendors enable 03 and 04 to be perfect mirrors of each other (that is what I would do), while others have completely separate data and both must be used.
The problem with function code #4 (Input Registers) is things like the old Modicon I/O scanner cannot access that data, so mirroring it in the #3/holding register space was the only option to sell to the maximum number of customers. Therefore, if all #4/Input space data must exist in the #3/Holding space, might as well just treat them the same.
But as I said, this is strictly a vendor-specific issue.
