Hello everybody I'm having a little bit of a problem with some pneumatic cylinder reed switches and need your help.
We have a pretty simple machine consisting of a slide and press. These machines are all over our plant and consist of essentially the same bill of materials.
One machine constantly stops during autocycle.
When looking at the reed switches on the cylinders during one of these instances the switch is stuck on (according to the LED) while it should be off. We are running a slc 500 brick that we've changed as well as 8 Numatics reed switches and three cylinders.
Do any of you know what could be causing these reed switches to be staying on? Thanks.
