I'm in need or a calculation for the following criteria.
If one has a 180 gallon accumulator tank and fills it with propane gas at 60 degree's (F) the accumilator as a input port of 1" and an output of 2", gas is stored at 30 psi. I need to know the volume under compression is (Cubic Feet),and when released through the 2" port, leaving the 1" fill port open for 5 seconds what volume is being used. If any one has a combination of formula's that can be shared, I would appreciate your help.
