Recently in one of our Frame5 gas turbine due to high lube oil temperature the unit could not generate power to its full capacity. The lube oil cooler has been cleaned manually as much as possible, the oil has been tested in a laboratory,and found ok. The cooling water line circuit has been checked thoroughly and found no abnormality. The problem is deteriorating day by day. If you have any idea to solve the problem, pls suggest.
