Z
In my project, I don't want the Operator use Work Bench to change something. But I found if there is any unable device in the run time, the speed that I set point will become slower than all the device avilible, if I make the unable device disabled in the Work Bench, the speed will become normal.
My problem is if I can make a script to disable some device instand of setting them disable in the Work Bench?
