I have a 2-wire RS485 with 15 slave devices using Modbus, this network is connected to a Fibre Optic to Copper converter which then sends the data across a fibre network to another converter which converts it back to copper, which is then connect to my PLC. The fibre network is used because of the distance and for isolation purposes.
How do I terminate this network correctly, I have had a couple of different suggestions, these are:
1) Terminate at either end of the entire network, therefore only two terminating resistors.
2) Terminate only the Slave Device end of the network.
3) Terminate each RS485 network therefore having a total of 4 terminating resistors as there is two seperate RS485 networks in opperation.
What is the correct method, or is it a case of NONE OF THE ABOVE?
