Bob
Hello,
I dont think you need to change your code, this is a similar problem i had while communicating with a PLC.
The serial converter sets itself up (with the help of the driver) as a standard com port.
So you need to go into control panel/system/ports and check which port it has assigned for the adapter eg com1/com2 etc.then you can set up your mscomm port settint to the correct port value.Beware if you have more than one USB port and you plug your serial adapter into a different one the computer will re assign a new com port number.
hope this helps
Bob
hope this helps
Bob
