hello friends...
i m new person in instrument maintenance. i want saturated steam flow with the help of following parameters.pls do needfull.
Actually, i want to find saturated steam flow q1.
i have p1=13 kg/cm2 , t1=191 C , q1=?
p2=15 kg/cm2 , t2=198 C , q2=3 T/H.
apart from that i have pipe dia.is ID = 105 mm and bita ratio is 0.43 if possible then pls write general equation for getting the above.
Thanking you.
Thanking you.
