How to get the camera data by using GE MDS SD9 radio?
Greetings of the day!
I use the General electric, MDS SD9 radio transceiver module for communication from the remote station (offshore) to the control room.
Setup: 1st MDS SD9 radio connected to Camera's DVR via Ethernet port available in both modules.
And in 2nd MDS SD9 radio is connected to a PC via Ethernet port.
I am able to ping the 1st MDS SD9 radio & DVR's IP Addresses from the PC. But, unable to receive camera data.
SD9 is Licensed narrow band aka small data (15-30kbps) for great distances. I would not expect live video data to work.
You will need to use still frames if you want video. No live data as I expect your latency is way too high.
You should be running packet with Mac and have bridge and smart filter enabled.
