N
I have a sensornet device which saves data onto the on-board hard drive. The data is stored as simple ASCII text files within a particular directory structure.
Running windows 2000, the folder where the data is stored is, by default, a shared directory and can be accessed over a LAN with the standard
Ethernet connection on the rear.
I am trying to read this data in ASCII format into Wonderware. Will the RPM kit help in this case?
