I have a solar inverter from Growatt (Model: MAX 70 KTL3 LV datasheet in attachment). I’m trying to read data from it using Modbus. For this, I’ve linked it to my laptop using an RS485 cable (with an USB-converter for my laptop’s USB port).
I’ve been having some trouble reading the parameters. I’ve done some troubleshooting and there are two things I need help with:
-Allegedly, I need to explicitly set the USB port I’m entering the USB-connector to as an RS485 port. This should be do-able in device manager. In demonstrations, I see a check box under the ‘port settings’ tab under the window that opens when clicking the COM-port in question. I, however, can’t find such a thing, also not under the ‘driver’ tab.
How should I be doing this?
-I’ve been told solar converters from this brand won’t give off any data if you don’t request it. The producer has given me some documentation with commands (attachement: Growatt Inverter Communication Command), but it’s badly translated from Chinese and I can’t understand them. Is anyone familiar with the commands written in this file and how I should enter them? Is there a specific type of software I need? How do I interpret them anyway?
