hi all
i need to make a small network of 3 computers, and an adsl router.
the cables run in a wall, and im using cat 5 cable, is it good?
i am trying for the first time to terminate the cable by myself, i am using T568A color standard as I read in the net.
And there is 1 thing I cant find an answer to!!!
the cable has a foil around the twisted pairs, and the RJ45 Connector is covered with metal, should these two be connected?
from my understanding the connection between them will insure the the foil would be grounded, is that good?
and 1 more Q: May I run the cat5 cable outside the building, between 2 floors?
btw: I do not use wall jacks
10x!!!!!!!
10x!!!!!!!
