Hi everyone.
I'm looking for a little advice on the selection of a DP Transmitter on a MEG filtration line. The client have specified that it must be connected to the process, via capillary tubing and a remote diaphragm seal.
The instrument is to be Int. Safe and is to be capable of being brazed to the capillary tubing.
The process date across the filter is
Design pressure 255.4 barg
Design temp -20 to 50
operating pressure 90-220 barg
Dirty pressure drop bar VTA
operating temperature 21 degrees C
flow rate 4.7 m3/hr - 7m3/hr
fluid flowing MEG
fluid density 1113kg/m3
fluid viscocity 1.4-2.0
ambient temperature range -8 to 25 degrees C
Any help would be massively appreciated!
fluid flowing MEG
