L
GAS TURBINE Frame 5 mark 6, now gas turbine , according to schedule hydraulic ratchet started so alarm coming on every 3 minutes. alarm is follows
....RATCHET TROUBLE...
WE have also started the heater to reduce the viscosity of lube oil or increase the temperature of lube oil because of cold weather. before heater started oil temperature observed 24 c deg. and after heater made ON oil temperature reached to 32 deg c. but the situation is same is that problem something else if so please help me about that matter. i will be appreciated
