We have an application where we are controlling the loading of a Press via hydraulic cylinders fed by linear hydraulic servo valves. The Bosch valves are controlled by analog-only Bosch controller cards which do the closed-loop pressure control. These cards receive a supervisory pressure setpoint from our DCS (Honeywell TPS).
We would like to do the closed-loop control directly in our DCS. This would greatly simplify the design (eliminate several troublesome signal transducers as well as the Bosch controller cards). However, the OEM is cautioning us that this probably won't work because the servo valves are high speed (operate full stroke in anywhere between 10ms to 32ms) whereas our DCS has a relatively slow (250ms or 500ms) scan rate. The OEM says warns that our tuning will have to be so slow that it will take forever (> 5 minutes) for the controller to reach desired setpoint.
I'm not a control expert, and I can't find any good literature or articles addressing this. Has anyone successfully used a traditional DCS for closed-loop pressure control where fast-acting hydraulic servo valves are the final control element?
