I need help programming a Idec Micro1 plc with a ladder program. I have very little experience with plc programming and I need to write a program that will automate a machine I am building. I will need many control functions such as estop, jog forward, jog reverse, start, stop, count up/down, if count = then, etc.
I know what the basic instruction set is and how it works, but I don't have any practical experience. My first problem is how do I get the estop to stop an entire block of program without having to enter the LOD out for the estop in each rung? Also, when the program comes to the END function, does the plc stop or does it simply go back to rung 1? If any one has a sample ladder program that has an estop and multiple motor start/stops and a counter perhaps in that program, I would really appreciate it. I just need an example of how it all works together so I can get this machine running. I can provide a flow chart and input/output list if needed.
Thanks in advance!!
bnelson
Thanks in advance!!
bnelson
