We have tried and evaluated:
Siemens Step7
AB Control Logix
Wago
Phoneix Contact AUTOMATIONWORX
They all use call defined "custom" function blocks by sequentially executing them by substituting the variables for each instance after each scan. This makes it impossible to debug a custom block while the processor is running.
We have found only Modicon Concept makes a new Instance of the DFB code each time, so you can drill down and debug the code while is running.
Are there any other PLC development system suppliers who can do this?
Steven Landau
VP
SPEC Process Engineering & Construction
Siemens Step7
AB Control Logix
Wago
Steven Landau
VP
