I am getting an "IEC Upload information not restored successfully Error Id: OLI-21735" when uploading from Quantum 140 CPU 434 12 into Concept V2.6.
I can upload the configuration but it fails in the IEC Program sections after uploading them for some time.
The original program was written in 2006 and then modified a few years later when a ProSoft Profibus module was added to the end of the rack. This module does not seem to be in the configuration that I am getting. Below is the config. Any help will be gratefully appreciated
P L C - C o n f i g u r a t i o n
PLC Selection
PLC Type 140 CPU 434 12
Exec Id 883
Memory Size 64K logic
Extended Memory 96K
IEC Runtime Enabled
IEC Usable Memory Size 848
PLC Memory Partition
Coils (0x) 2512 000001-002512
Discrete Inputs (1x) 1008 100001-101008
Input registers (3x) 9999 300001-309999
Holding registers (4x) 9999 400001-409999
ASCII Setup
Total Message 0
Message area size 0
ASCII Ports 0
Configuration Extensions
Data Protection No
Peer Cop Yes
Hot Standby No
Ethernet 1
Profibus DP No
Specials
Battery Coil 001248
Timer Register No
Time Of Day 400700 -400707
Duplicate coils No
First Coil Address -
Watchdog Timeout [ms*10] 30
Online Editing Timeslice [ms] 20
I / O M a p
Remote (Head slot 0)
Drop Type Modules Holdup[ms] Input-Bits Output-Bits
1 Quantum I/O 8 300 160 64
Local Drop
Drop Type: Quantum I/O Drop 1
Slot Module name Input Range Output Range Module description In/Out-Type
1-1 CPS-214-00 DC Summable PS 24V 8A
1-3 DDI-353-00 100001-100032 DC Input 24V 4x8 BIN
1-4 DDI-353-00 100033-100064 DC Input 24V 4x8 BIN
1-5 DDI-353-00 100065-100096 DC Input 24V 4x8 BIN
1-6 DDI-353-00 100097-100128 DC Input 24V 4x8 BIN
1-7 DDI-353-00 100129-100160 DC Input 24V 4x8 BIN
1-8 DDO-353-00 000001-000032 DC Output 24V 4x8 BIN
1-9 DDO-353-00 000033-000064 DC Output 24V 4x8 BIN
PLC Selection
Exec Id 883
Extended Memory 96K
IEC Runtime Enabled
ASCII Setup
Total Message 0
Message area size 0
ASCII Ports 0
Data Protection No
Peer Cop Yes
Hot Standby No
Ethernet 1
Profibus DP No
Specials
Battery Coil 001248
Timer Register No
Duplicate coils No
I / O M a p
Local Drop
