iFIx and Ms Access
Moret, O.
Dear List,
Is it possible to include a Form made in MS Access in a iFix picture. Some one told me about ActiveX components etc... , but the problem is that i am not a Wizard in iFix.
Another problem is: What type of block do i use to get information from an existing Db.
I tried the SQL one's but i do something wrong with the definition etc. (The part in the SCU and the ODBC in Nt is done according the manual. Hopefully)
Databasename is Cableprog.
Tablename is Cable_gr
Fieldnames in Cable_gr are: group_desc,drawing_set_sheet
Met vriendelijke groeten,
Onno Moret
Imtech Projects West
Mescon
Control Systems
tel :010-4477228
fax :010-4477210
mailto:[email protected]
Bezoek onze Internetsite (klik hieronder)
http://www.mescon.imtech.nl/
Any opinions expressed in this message are not necessarily those of the company.
P
Patryck Valdez
YES!!!
Its possible and very simple
You have several ways to do this....
By ODBC
By iFIX Tags
By VisiconX (activex objects)
By iFix Tags... the most complicated one
you have to follow the SQT and SQT tag types
to make this.
By ODBC... a simple one
go to the electronic books and search DAO or RDO this are connectors to databases and you can copy paste the code to your picture and retrive or send data from any ODBC compilnce database
By VisiconX ... the most easy one
You need to buy from intellution this activex objects, then you select a database conecto object that includes a wizard to make a conection to your database, then you put a grid control and link it
Thats it
I hope this help
