Hi. You ask about software for capturing data from a s5 cpu. There is a neat software made for this purpose it has order no: 6ES5886-2WQ01 - Prodave toolbox win/511 , it comunicates via the com port on the PC and to the AS 511 programming interface on the plc
> Does anyone know of any application for importing S5 data into Windows applications or a dinamic library for do it in visual basic? > > Thanks
i have made an application that reads Data blocks, inputs, outputs, flags, timers, counters from S5 via PG port. (also capable of writing to those areas) i didnt make that application as DDE server or in DLL (API function) form. Will it be beneficial for you?
Dear Mr. karasu
How can obtain a copy of that application? Can you send me it via email?. If this is possible for you my email address is [email protected]
I have a solution for Read/Write a DataWords to integrate your visual basic project, is a economic solution and a easy programing. You can contact me at [email protected]
Dear Mr. karasu I'm alse interested in this application, would you please send me any information about this program too. Lot's of thanks in advance. N. AHMADI
Each CPU stores datablocks, timers, counters and flags in RAM at precise memory locations which differs according to CPU type.
You may refer to the CPU manuals for the correct memory offset of every area or just ask the PLC (via AS511 functions) for such information.
