how do you increase the starting torque on a AB 1336 plus II drive?
D Thread Starter don thompson Oct 21, 2003 #1 how do you increase the starting torque on a AB 1336 plus II drive?
G Gord Kennedy Oct 23, 2003 #2 Hey: You want to set the DC Boost parameter so that it will overcome the IR drop at the stator and give you some extra starting torque. This is Parameter 48 in the Motor Control group. The manual is available at http://files.awdm.com/e-files/ra/1336f/1336f-um002b-en-p.pdf or I can email it to you if you like. Good Luck, Gordon Kennedy Logic Systems Engineering Ltd
