Hi everyone,
I would like to have your opinion about the use of individually isolated outputs in a PLC application. Should i use it for motor control? even if the motors are all in the same MCC?
Also, what are the good practices for emergency stop on those motors? Since the control voltage comes from each starter, the MCR has to interrupt
each output individually, requiring one set of contact for each. How can i avoid a hard relay panel inside a PLC panel?
Thank you for any comment...
Pascal Poirier
[email protected]
Pascal Poirier
[email protected]
